NOAA Weather Patch to Mototrbo System
mwuc14
Cincinnati, OH
Working off a XPR8300 and a mix of digital and analog channels is there a reliable way to have a NOAA weather radio transmit (possibly a VOX feature) on the primary channel for when there is a weather alert for the county the system is in? Has anyone tried this type of setup before?
mwuc14
N1GTL
CT
Mix? Does this mean the repeater will work digital or analog, first in first out? Mixed Mode? If so, I doubt it. What talk group ID would it transmit? That's determined by the subscriber. I think you'd need a SAME receiver tied to a control station and have to broadcast it that way.
Firebuff880
Boynton Beach, FL
mwuc14
Our solution can take EMWIN alerts an distribute a device aware parsed version of then as text to users or groups.
If you want audio, you could combine EMWIN, ASTERISK, APP_RPT, IBM''s TTS engine together to do a group and or direct call announce using the Repeters telephone interconnect EID.
https://www.ibm.com/watson/developercloud/developer-tools.html
https://pbxinaflash.com/community/threads/revolutionary-tts-coming-soon.21162/#post-129562
mwuc14
Cincinnati, OH
The zone has a mix of digital and analog channels but the repeater is managing a digital frequency. The weather alert would be transmitted from a mobile mototrbo radio used as a base/control station in our administration building also used for regular voice transmissions. I'm looking for a setup that would transmit the weather alert from that radio to the digitally repeated channel.
ResQguy
Meh
Thunder Eagle, Inc. - Radio Wireless Alerting Systems
