APX8000 antenna
eallen750
I have an APX 8000 dual band portable radio with an 8" U/V 7-8 GPS antenna. I'm looking for a shorter or "stubby" antenna instead of this one that sticks into my armpit.
Motorola does not offer a "stubby" antenna for this radio. I'm willing to sacrifice a little coverage or performance for a shorter antenna.
Suggestions? Thoughts?
n3obl
Ø
PA
If you want to sacrifice then order a 6000 single band stubby antenna
N4DES
Retired 0598 Czar ÆS Ø
South FL
You didn't say what, if any band you can sacrifice. If you can due without UHF the NAR6596A antenna is very good performer in VHF/700-800 and has a lower profile.
mikegilbert
MHz so good
Los Angeles
What are the primary bands you monitor? Here in Los Angeles, I use the PMAT4005 UHF/VHF antenna with great results. LAFD's conventional analog 800 system has enough of a footprint to come in well with that antenna.
It's also only 1/2" longer than a single band UHF antenna.
My 8000 with the PMAT4005:
ME801
NV
MX300-R, been along time since I've seen on of those.
And I've had good results in a very rural area using the NAR6596A antenna on my 8000XE.
Asmitty0010
New Hampshire
+1 on Mikes reply. I also use this antenna on my 8000. Works extremely well!
