What can I do with what I have?
SpringHill
Spring Hill. TN
I've recently come to own 2 Motorola HT1250 LS+ and one CDM1550 LS+ in the UHF band. I've posted a few times in regards to questions about them but I feel I honestly need some deeper understanding. I have these three radios and I own the latest CPS/programming cables but I have no idea what I can truly do with them and what is legal. I own some "business band" vhf Motorola radios and moving over into the pro world is a whole new ball game. I have a general understanding of two way radios and I do know what CPS does I just don't know what it all means and how it all works together. I HAVE done extensive research but it all leads me down bunny trails (repeaters/talkaround, arps, squelch and codes, ect, etc.) as I'm easily distracted by learning and I just get lost in the never ending puzzle that is "two way". I just need to know what I can do with what I have! Any help is appreciated!
marcotor
I ♥ÆS Ø
Sunny SoCal
The CDM series are great radios. I have a couple of 1550's that were surplussed from our fleet. I use mine for both GMRS and Amateur use. If you're not licensed, there ARE things you COULD do, but I doubt you will find much help from the users here.
I'm sure you already know, GMRS licensing is cheap, and it covers your entire family.
SpringHill
Spring Hill. TN
ill be leaving town tomorrow morning so for the moment ive got one 1250 hooked up to my computer broadcasting my department to zello. its all working correctly but there seems to be a lot of line noise or white noise coming through when they transmit. right now im just using a 3.5mm off the handsfree mic into the computer which isnt ideal but im not sure how else id run it. any ideas on the noise or other wiring options? thanks all!
chief21
Summer - Western NC; Winter - Tampa Bay FL
FYI... Along with some other pending changes to the Personal Radio Services, apparently the FCC is moving to extend the GMRS license period from five to ten years (for the same price), so you might want to wait a bit if you're planning on getting a GMRS license.
John
Project25_MASTR
Millennial Graying OBT Guy
Texas
If you unplug the cable (interfacing to the sound card) from the radio, is the noise still present?
SpringHill
Spring Hill. TN
Nope, that's how I know it's line noise. The cable isn't ran next to anything carrying current and it's pretty shielded regardless. Everything is properly connected and seated properly
Project25_MASTR
Texas
Your pulling amplified audio off of portable if I'm reading your setup correctly.
SpringHill
Spring Hill. TN
It shouldn't be "amplified" other than just what the radio sends to the hands free unit. It's set to vox obviously, but I have tinkered with the gains and hold/release times. I've also noticed that every once in a while I'll get that white noise transmitting trough and keying up zello even if there is no radio traffic. Maybe once for 10 seconds 2 times daily. Atleast that's the average to date.
Hey thanks for the heads up! Any idea on when that is?
Later on in the summer, IF the new rules get approved.
The new rules will be discussed at an FCC meeting in May. If there are no issues, MOST of the new rules will go into effect 90 days after that..
As has been said, without an FCC issued license you cannot transmit with these radios. There are no "license free" services that these radios would qualify under.
They make great receivers, as you've discovered, but that'll likely get boring after a while.
Amateur radio is an option, as you can use them on the 70 centimeter amateur radio band. Each individual person requires their own license.
GMRS might be an option. One license would cover your whole family. Putting one of these in as a base radio at your home, one in a vehicle, and having the portables, would make a pretty good setup. There are some type acceptance issues that would get in the way, but there are some trying to get that addressed in the proposed rule changes.
cmdrwill
So Cali
I wonder IF he is getting his "audio" from the correct place?
Off the speaker leads IS BAD and a no no. Use the Filtered Audio pin, and that is line level and not affected by the volume control. You still need a DC blocking capacitor.
