Motorola 7500 Dispatch console
Fdnavy
Is there a way to run to mics in one console. Our department is in the unfortunate process of handing off Dispatch operations to the PD. Right now if the PD dispatcher wants to talk to a fire unit he has to either change the select radio or use the touch screen to talk on the unselected channel. Is there a way to have two selected channels with two separate mics?
Project25_MASTR
Millennial Graying OBT Guy
Texas
That pretty much goes against all console logic…I'd say use the backup radio at the position as the I selected transmit.
sfd119
What's the issue with talking on an unselected channel? I do it quite a bit. Otherwise you click on it and make it selected....
riveter
MD
Yeah they gotta just instant-transmit or change select. Instant transmit is the recommended method. There is no method in MCC7500 to have 2 select channels.
