APX-8000 Wrong Battery Indicator
AESFTW
Getting a wrong battery alert when using a Impres 2 High Capacity Battery. When using an FM approved battery I do not get the warning. For radio certification selection on CPS, its defaulted to None and when I click the drop down, none is the only option. Both batteries worked fine on the APX7000 and the high capacity battery is relatively new (4 charges). The battery was conditioned correctly and displays the correct Impres data on the 8000.
AESFTW
I'm just curious as to why none is the only available option for radio certification and if that may have something to do with it. If not then is there a way to turn off that audible/visual alert without shutting off all alert tones? Whats weird is I just popped it on a non-Impres battery eliminator (Off Brand Vehicle Adapter) and did not get the wrong battery error. Of course when I clicked battery on menu it simply stated smart battery data not available.
jmarshl
San Diego, CA
Motorola told us you only get options to select if you have an intrinsically safe battery on an intrinsically safe radio. We have not been able to confirm this with testing.
AESFTW
You only have the option of "none" because the other options only appear on radios that shipped with IS certification.
Take a look at this, it may be the battery itself. https://www.motorolasolutions.com/c...tn-0106-17-na_impres2_battery_programming.pdf
I will take a look at it when I get home from work and check model number and date code. They provide a number to order a new battery and to reference the defective battery. Hopefully they will discount or honor this. Its still weird that it works fine on a 7000 and still provides battery data on the 8000 just flashes red and says wrong battery.
