CDM750 No Low Power Option
fdnyfish
Barnesville, PA
When I'm in Conventional Personality under Options, TX Power Level only has HIgh in the dropdown box. How do I select Low Power for a channel.
I was going to use the P1 button to select high/low power (it does work using the P1 button), but the light above P1 does not illuminate when I press the P1 button.
So there is no way to tell if i'm in Low or High power unless I have a meter connected
clbsquared
Isle of Wight County
You program hi/lo power in your button assignments. What else do you have programmed on the P1 button? And do you have it programmed for long press or short press?
Sent from my HTC One A9 using Tapatalk
fdnyfish
Barnesville, PA
It's programmed for short press, but the light above P1 does not light up.
I also tried it on the long press of P1, and same thing ni light indicator.
It does work hi/lo power with the buttons, but i need a visual whats on
