CDM1550LS+ programming error
Priority-One
Anonymous participant
Banned
Bronx, NY
I just got a new radio to use for my scanner feed and I programmed it with RX only and get an Error after I wrote the code plug to the radio. I am programming RX only for NYPD queens. Any insight?
Priority-One
Banned
Bronx, NY
I figured it out. I set the signaling setting wrong and rectified it. Will the fdny frequencies be able to be entered? What is the split? Because all i see is 12.5, 20 and 25 splits
IAmSixNine
Dallas, TX
That little indicator above the U looks like the passport indicator. If memory serves me correct there was always one zone if those radios to hold the spot for a passport system since it was an add on board/feature of the original CDM radios.
Hopefully you assigned the channels to a zone, then you can assign a button to change zones and go to where you want to listen.
