fonestar
Hi there... programming a PR1500 using CPS.
I can't seem to de-select TA from memory channel 16. Why is that?
Right now I've set 16 as a simplex channel as a temporary work-around but that's not the way it should be. I have other radios and I want all of the memory banks set up the exact same way.
Channel 16 should be a repeater frequency with no TA enabled. I have a total of 16 channels programmed in this radio, no priority scanning, no trunking. No other channels are programmed with TA.
