Motorola ht750 usb cable won't read
crc101
hi I'm running windows xp 32 bit. I have a usb cable not serial. I have the cps and when I go to read the radio I get this error.
Couldn't open port. Check whether device/Rib are powered on or not, and the device to rib, and the rib to pc connection is OK.
anyone who can help please do
-crc101
tdeater
Fremont, MI
look in the device manager with the radio and cable connected and see if you have any COM ports listed. One of those will be the port that the radio is connected to. You have to tell the software to use that port in one of the menus. If a com port is not listed in the device manager, you may need drivers or something for your programming cable. Those usb cables are typically a USB to Serial adapter.
crc101
Motorola ht750 usb cable wont read
I have already installed the prolific driver for the cable and device manager is already setup for com port 3
Nasby
Ohio
I personally have never had any luck with a USB / Windows XP programming combination.
I'll bet if you use a programming cable with a true serial port your problem may be solved.
SCPD
QRT
Virginia
I do recall with the prolific driver, you would need to locate the exact one that would work. Most the time the driver provided does not work.
I forget where I found it but a true prolific driver when I did a search I had to try a few before I had any luck. It depends on the version I would have to check what version I had used to get one of them cables to work.
It was more of a experiment. It did read and write. Figuring out the actual prolific driver was the fun part.
You would also need to be sure your cable has a true prolific chip.
putterizer
WI
You will need to find an older Prolific driver and install it, rather than a newer one. That is what worked for me.
If memory serves me correctly, it was version 3.0.0 or less. I will have to look when I get home.
jaspence
Michigan
Com port
I use a true serial cable for the HT 750 and 1250 with XP, as well as other Motorola radios. Software designed to work through a true com port does not seem to translate well into a USB port.
armymarshall1
Colorado
I like to call it the old nintendo trick. Sometimes the cartridge a little hot air, breathe on it a little bit like you would to fog up your glasses to clean them. Then try. Ensuring that the contacts on the accessory flex are clean and intact is key.
