Motorola XTS5000 Unit ID
rivera293
So in my XTS 5000 I monitor my local Police on a P25 system, I have The ID feature turned on but it only displays a series of numbers... which is boring and I wanted to know if there is a place in the CPS where you can plug the ID number in and customize the name of the ID so instead of numbers you can read whatever you named that user. Is this possible? Thanks in advance
rescue161
KE4FHH
Hubert, NC
If you are talking about a trunked system, then the ID List is located under "Trunking/Trunking Call Lists." If you are listening to a conventional frequency, then the ID list is located under "Conventional/Astro Systems/Astro Call Lists."
You need to add the ID and then assign an alias so the alias will show up instead of the ID. This won't make much since if the users don't keep the same radios. Adding dispatch to the list is easy as their IDs don't change, but portable radios can change hands every shift. Good luck.
rivera293
Thank you for the help! I wondered what that did but never messed with it until now.
rivera293
I’ve tried this and somehow it’s not working and still displays the numbers
Project25_MASTR
Millennial Graying OBT Guy
Texas
For some reason I want to say enhanced I'D doesn't function when scanning. Been awhile since I bothered messing with it though.
Sent from my SM-T713 using Tapatalk
rescue161
KE4FHH
Hubert, NC
You also have to go to "Radio Configuration/Display & Menu" then select the PTT ID Tab. Then check the "ID Display" box and change the End of Voice Timer to how ever long you want the name to remain on the display. I use 4 seconds and it works great. If you want it to display the ID during scan, just check the Scan ID Display box.
If you have already done this and you are still only showing numbers, then you may not have that feature in your flashCode.
