Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
  #21 (permalink)
Old 02-05-2018, 4:09 PM
N1GTL's Avatar
RDAC, in and of itself, WILL NOT narrow down an SWR problem. The question and first 5 posts were all referencing the duplexer being the issue (which it was). That's what I addressed.
Connecticut Database Administrator
  #22 (permalink)
Old 02-05-2018, 4:10 PM
N1GTL's Avatar
When you say you get nothing....do you mean no output power? or nothing reflected? If no output power, you have more work to do. If your reflected is nothing, you should be set.
  #23 (permalink)
Old 02-05-2018, 4:43 PM
MCore25's Avatar
Bypass the duplexer and see what you get. Hook the transmit side of the repeater up directly to the antenna and just leave the receive port of the repeater disconnected (key it with a portable). If SWR is under 2.0:1 (ideally you'll want under 1.5:1) that is working properly. Then go and test both the transmit side of the duplexer (meter between repeater and duplexer) and output and compare results (also compare forward power if possible and put it into a log comparison, if it comes out to more than 2.5 dB of loss you have duplexer issues).
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
  #24 (permalink)
Old 02-05-2018, 5:24 PM
Originally Posted by MCore25 View Post
Which can be done through RDAC via the process of elimination (test repeater into a load, test duplexer into a load, test antenna) using the built in tools. If one doesn't have access to a SWR meter you can still figure out where the issue may be centered around. Just another tool to use to reach the same conclusion.
What would a good SWR reading be?
Nevermind :|
Last edited by jackel0228; 02-05-2018 at 5:26 PM.. Reason: Just saw previous post.
  #25 (permalink)
Old 02-05-2018, 5:25 PM
No movement on the Power/SWR meter.
  #26 (permalink)
Old 02-05-2018, 5:27 PM
I Don't have all the connections/adapters to get my meter between the radio and duplexer. I thought about doing that too.
  #27 (permalink)
Old 02-09-2018, 7:13 PM
So I finally got it all worked out. It was definitely a duplexer with the TX and RX swapped up. I show 28-30 watts of forward power and a little less than 3:1 swr. Seems to be working fine now. Thanks for the help...
Sent from my SAMSUNG-SM-G891A using Tapatalk
Tags
cps, dmr, motorola, programming, repeater
