Motorola DMR Programming question/s...
jackel0228
Texas
I've been trying to figure this out and obviously I'm stumped because I'm here asking for a little bit of insight....
I've got several radios all programed and working on my licensed frequencies using my licensed copy of the CPS. Just getting that out of the way. So before I added a repeater to the mix everything was operating fine. When I got the repeater and got the duplexer re-tuned I put it in the mix. So now when I try to transmit through the repeater my radios will key up like they're supposed to, but only in very close proximity to the repeater. Like within 200 yards. Once I'm beyond that the channel "bonks" me out... IE I get busy channel tone. If I enable talkaround, back to normal operation.... So my question is even if I'm outside the range of the repeater (which I definitely shouldn't be) shouldn't my radio still key up and transmit?
My admit criteria is set for always, and everything else is as open as I can make it.
Any insight into this matter would be greatly appreciated.
KevinC
Other
Super Moderator
Home
Others will probably have more suggestions, but I vote for...
1. Duplexer is mis-tuned and you have too much insertion loss on either TX, RX or both.
2. Duplexer is mis-tuned and you have desense.
3. Repeater is mis-aligned.
jackel0228
Texas
How would I know if if duplexer was mis-tuned?
Okay so I forgot to say that I bought the repeater and it came bench tested and repeater was tuned for a GMRS pair. Duplexer too. So to test my new purchase, I programed a mobile and HT along with the repeater for a digital channel using the frequencies that came with the duplexer. Hopefully that makes sense.... Anyway it appeared to work fine, although extensive testing was not done... So I thought I had tested it sufficiently.
Sent from my SAMSUNG-SM-G891A using Tapatalk
mikewazowski
Staff member
Forums Manager
Oot and Aboot
4. Duplexer is hooked up backwards.
N1GTL
CT
3rd vote!
If you have access to an SWR meter, check forward and reflected between the repeater TX and the duplexer. Do this with a dummy load in place of the antenna. If it is tuned poorly, your SWR will be high. If it is tuned perfectly, you should see no reflected.
jackel0228
Texas
4th vote.
Also make sure you did not force PL-259 connectors onto N connectors like I did once. BTDT.
I'm on my way to check it now. The repeater site is only about 5 minutes from here. It would not be the first time the shop I had it tuned at screwed up
jackel0228
Texas
Sorry for the very basic question... You mentioned that the repeater was formerly programmed with GMRS channels -This IS a digital repeater, right?
John AC4JK
Yes it is. And I have located the problem. Duplexer reversed. So now my question is, can I just switch the jumpers from rx and TX? Or is there something within the duplexer itself that would prevent that from working?
kayn1n32008
ØÆSØ
Sector 001
Just switch the jumpers. Things should work after you do that
Project25_MASTR
Millennial Graying OBT Guy
Texas
3rd vote!
RDAC will actually log high SWR. Used it on several occasions to check repeaters.
Most recently, I got called back on an install I did. Get there, quickly see I left the antenna disconnected from the duplexer. Check RDAC…and we are working but instead of seeing an error saying 35:1 SWR it’s now saying 28:1. So I throw a load on the PA output. No errors in RDAC, everything is happy. Then I check the duplexer. Looks as labeled but I decide to pull the labels (which I had made) and check the OEM labels. What do you know, I mislabeled the thing. Swapped the labels around, swapped the jumpers and all was well.
N1GTL
CT
It will give you high SWR alerts but it will not give you the REASON. High swr could be caused by a number of things. My suggestion was for checking to make sure the duplexer was tuned correctly.
Project25_MASTR
Texas
3rd vote!
masstech
John AC4JK
Motorola does not sell analog-only repeaters. The "cheapest" you can go is a MOTOTRBO repeater, and you configure it for analog.
The hardware is good, just configure it to analog only so you are within Part 95.
The FCC knows well that there is Part 90 only type certified equipment in use in GMRS and acknowledges this. Still not legal, but their publications sound along the lines of "follow Part 95 and keep your nose clean".
jackel0228
Texas
Don't need to do all that, because I have a part 90 license. Which was also totally unrelated to the subject. Thanks for the info though.
Project25_MASTR
Texas
Which can be done through RDAC via the process of elimination (test repeater into a load, test duplexer into a load, test antenna) using the built in tools. If one doesn't have access to a SWR meter you can still figure out where the issue may be centered around. Just another tool to use to reach the same conclusion.
jackel0228
Texas
Okay so new questions have arisen... If I attach my swr meter to the duplexer output, with my antenna attached (no dummy load available) I get a 3:1 swr reading and about 25 watts of output power.
If I swap the leads on the duplexer, I get nothing.
So I'm guessing way 1 is the right way haha
