Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
  #21 (permalink)
Old 03-17-2018, 2:32 PM
take small wire from pin 25 of assy connector to 12v and see if it power up
  #22 (permalink)
Old 03-17-2018, 2:56 PM
Priority-One's Avatar
I donít have the accsy connector yet. Hopefully when it comes in this week I will be able to power it up.
Check out my feed on Broadcastify.com - NYPD 108/114th Precincts.
  #23 (permalink)
Old 03-17-2018, 3:00 PM
rescue161's Avatar
KE4FHH
The black part on the screen is normal.
Yes, you must apply power to pin 25 if it is programmed for ignition sense (most are).
Hams Against Magnetic Mounts
  #24 (permalink)
Old 03-17-2018, 3:01 PM
So when the cable comes, I have to cut the cable and wire it to the new cable? Sorry if Iím looking stupid here. Just trying to get it right without blowing up the radio.
  #25 (permalink)
Old 03-17-2018, 3:09 PM
rescue161's Avatar
KE4FHH
No. The cable, if you ordered the dash-mount cable, will come with 3 wires coming out of the plug. Two are for the speaker and terminate to a two-conductor plug that plugs into a standard Motorola speaker. The other wire is red and is fairly long. It will have an inline fuse. You connect that wire to your "switched" power source (power that comes on when you start your vehicle and turns off when you turn off the vehicle). The main power wires that you already have connected remain on constant power at all times. If you are using this on a bench, then connect the red switched power (pin 25) to the same source as the red main power lead.
  #26 (permalink)
Old 03-17-2018, 3:17 PM
Mr_Boh's Avatar
No. That's where your red yellow and green status LEDs are.
  #27 (permalink)
Old 03-17-2018, 3:18 PM
Mr_Boh's Avatar
  #28 (permalink)
Old 03-17-2018, 3:58 PM
For testing to see if it works today you do not need the connector just a small wire to apply 12v to ignition sense pin,however if you do not understand that you may be better off waiting for the connector.
  #29 (permalink)
Old 03-17-2018, 3:59 PM
I rather wait for the connector as I donít understand the power aspect other than the plug in. I see the pins on the back. But to afraid to mess with the electrical side of things unregulated.
  #30 (permalink)
Old 03-17-2018, 4:07 PM
Ok I understand that I was just trying to help you out after reading post 8 to hopefully brighten your day.
Good luck hope your connector comes in soon.
  #31 (permalink)
Old 03-17-2018, 4:12 PM
I definitely appreciate it. I just donít wanna be thrown across the house lol. I canít wait to get it working and replace the CDM. This is a current picture after I cleaned the XTL.
  #32 (permalink)
Old 03-17-2018, 5:01 PM
MCore25's Avatar
If you donít know where that radio came from, Iíd suggest powering it up without an antenna connected.
Old FCC rules used to require ignition sense. These days you see it more commonly in trunking systems as itís used to de-affiliate a radio upon shutdown.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring youÖ
  #33 (permalink)
Old 03-17-2018, 5:04 PM
The radio was on the type Ii smartzone system but they since moved to 700mhz Phase II with APX mobiles. Iím assuming itís still programmed for the old Doitt system. Iíd like to have someone program a new code plug for me since Iím using it only for conventional P25 and analog. Itís just gonna be for RX only.
  #34 (permalink)
Old 03-17-2018, 5:21 PM
If the radio came from a trunking system, you had better put a dummy load on the mini UHF connector on the radio before you try powering it up. The radio will try to affiliate as soon as it boots up. That's just the way it works.
You could cause damage to the transmitter PA with out a load on the antenna port.
Trying to program the radio will require a system key to change the existing trunking program settings.
Good luck with your efforts. You do have a fine radio to work with.
Jim
  #35 (permalink)
Old 03-17-2018, 5:27 PM
Iíve blown out ASKís with depot on an XTS5000 and Created a new code plug. But never with an XTL. I have Astro depot, but at afraid to brick the radio.
  #36 (permalink)
Old 03-21-2018, 7:32 PM
I got the cable in the mail today and plugged it in and still for no power.
What do I need to do with the black cable?
  #37 (permalink)
Old 03-21-2018, 7:33 PM
Mr_Boh's Avatar
You still need the other power cable. Just wire the cable you got with the red cable from the main power cable.
  #38 (permalink)
Old 03-21-2018, 7:49 PM
I was trying to strip the red wire back and bit and ripped it out of the pig tail. But I still am not getting any power to the radio. I think Iím gonna have to find someone I can send it to that can check it out
  #39 (permalink)
Old 03-21-2018, 7:54 PM
rescue161's Avatar
KE4FHH
From your picture, you don't have the main power plugged in. You have to plug in the main plug and the 26 pin plug.
  #40 (permalink)
Old 03-21-2018, 7:56 PM
I broke the red wire out of the main plug trying to strip it. So I just ordered a new one. But I plugged my main power cable in after I tried to put the red wire back in. And still no power.
