APX BAND PLAN am I doing something wrong?
rivera293
I have a Motorola APX 6000 set up for non affiliate scan of a trunking p25 system. My flashcode has TDMA enabled and I think I did everything correct while entering the band plan however when a phase 2 talk group comes on it just shows the talk group on the screen but no audio comes through.. am I doing something wrong? Any help and advice is appreciated. All other phase 1 talk groups work just fine.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Your channel spacing is off on your TDMA channels. Unitrunker is reporting a 6.25 kHz channel spacing and your APX bandplan is setup for 12.5 kHz spacing.
jtech48
OVB
This is just my .2 cents. Based on the history of how posts speaking about this specific topic end, I strongly suggest you do a little more searching online if you wish to continue to monitor a trunked system this way, there are a couple other threads in this site as well as some other where you can find some useful info.
Be forewarned that the question of whether you're a legitimate user on that system and how you obtained a system key will most likely be asked.
rivera293
I tried the 6.25 and it’s still not working
