Hi, thinking of purchasing a Motorola CDM1550 LS+ but see that some on ebay are advertised as 450MHz and others are 430MHz. But looking at the spec sheet it looks like the radio's do both anyway, is this true or are there two versions of this model?
Regards Lee.
Which one you choose really depends on what you are licensed for and what your future usage will be.
If you are using these for work, then pick whichever one covers the frequencies you are licensed for. There is the overlap, so that can be handy.
If you are using these for hobby use, like GMRS or Amateur, get the 430-470, as that will cover the 70 centimeter band as well as GMRS. Even if you don't have an amateur license now, you may decide to go that route in the future. The 430-470 split will be easier to sell to amateurs/hobbyists later on if you need to.
These can be taken slightly out of their intended bands, but only a bit, and it will vary from radio to radio where the VCO will unlock.
Good radios, I'm using VHF CDM's (750, 1250 and 1550's) for all my personal vehicles. I've got a few at work, too. I've picked up 750's for as low as $75 and 1550's for as low as $150.
