PMLN6208 Case Removal Tool for XPR7550, Photos????
Batman_
For XPR-7000 series, DP4401, and others use this tool.
on-line price of ~$250 US.
I am hoping to find some detailed photos of this tool.
Perhaps if someone has a photo of the tool placed on a sheet of graph paper, that would really help.
Thanks.
B_.
zacabo
FL
Thanks.
B_.
I have never needed a special tool to remove the case. Just remove the name plate (XPR 7550) at the top of the case. It will slide down toward the battery compartment. Then remove the volume and channel knobs. Next with a small screw driver carefully pry up in the two points in the photo.
XTS3000
Motorola is crazy for that price of the case opener tool for the 7550 & APX1000/4000. I bought the MagOne (BPR40) case opener tool for about $14 and used a metal file to file about 2mm off from both inner sides of the metal tangs. Works perfect, and also works good for removing the top knobs.
