Motorola APX Scanning
zacabo
FL
I finally had some time to program my APX 7000 to scan a local police department (Fort Lauderdale FL). RR lists it as being phase 2 but my XTS5000 is sitting here scanning while my APX is not. I have successfully programmed a type II system in the APX and it is working. The radio will stop on a scanned channel but there is no audio. I have done some research and I believe it has something to do with my band plan. I have used unitrunker. I have it set to not validate the NAC although I know some will swear by this and others like Mikeoxlong say it makes no difference.
KevinC
Other
Super Moderator
Home
It would work a lot better if the bandplan in the APX matched what you are showing in UT.
zacabo
FL
This is the first time I have ever used unitrunker. I'm guessing the offset is incorrect or I mixed up the TDMA vs FDMA. A little help please
RF-Burns
Your band plan is wrong. 700Mhz is a +30.00000 Offset and your Phase II TDMA frequencies must be in columns 9 and 10.
So FDMA in Columns 1 and 2 and TDMA in Columns 9 &10.
KevinC
Other
Super Moderator
Home
...and your Phase II TDMA frequencies must be in columns 9 and 10.
Umm...no.
The UT screenshot shows exactly how it needs to be (except UT starts at 0 and MSI starts at 1).
RF-Burns
I guess I wasn't aware the FCC gave Public Safety the 730Mhz portion of the 700Mhz band. 762Mhz -30.0000 offset is 732Mhz. You might want to look at the band plans again. But then again maybe I was asleep when the FCC auctioned it off.
KevinC
Other
Super Moderator
Home
He has multiple issues, your offset report is one of them.
Nothing goes in 9 and 10, according to the UT screenshot.
zacabo
FL
If you don't know what you're doing .. you shouldn't be doing it .. especially on someone else's system!
Thanks for the info I'll keep that in mind. After some more searching I was finally able to get it working. I ended up using a Uniden Homepatrol 2 to record activity on the control channel. I then put it into pro96com to decode the data. Pro96com was able to give me the correct base frequency and offsets.
zacabo
FL
Looking back at my previous post I now realize Unitrunker was giving me the same info I just wasn't reading the table correctly.
