Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Motorola Forum
Motorola Forum - For general discussion of Motorola land mobile radio equipment and their trunking technologies.
Old 06-05-2018, 11:56 AM
MedicDavid78's Avatar
Question XTL-5000 question
Hey y’all,
Got a quick question that’s boggling my mind. I have an XTL-5000 and every time I power it on manually the screen displays a readout saying “PWROFF NODELAY” for a second and then boots up normally. I’ve tried googling and have gotten nowhere. Can someone tell me what “PWROFF NODELAY” means cuz this is a new one for me in years of programming radios & scanners... Thanks!
Real-Time alerts for Catawba, Lincoln, & Gaston Counties!
Metrolina Alerts Facebook
Metrolina Alerts Twitter
Old 06-05-2018, 12:09 PM
davidzimmerman's Avatar
does it have the IGN Power Wire?
Old 06-05-2018, 1:34 PM
No, does it still need one even tho I'm not using the IGN? I turn it on and off manually with the push-button. My setup didn't come with an IGN Sense wire.
Old 06-05-2018, 1:40 PM
MCore25's Avatar
XTLs can get away without ignition (though none of the 5000’s I have setup do that) but they have to have the emergency pin jumped to ground.
If a repeater IDs and no one is on frequency to hear it, does it even make a sound? Yes, because KC5MVZ is monitoring you…
Old 06-05-2018, 1:43 PM
Hmmm maybe I'll try that.
Old 06-05-2018, 3:09 PM
My base XTL’s don’t have the ign wire, but the ign setting in the CPS is programmed that it doesn’t need the 12 volt ign wire. But the plug still needs to be plugged in for the speaker, & jumper, so the radio will work. However in my car, the XTL’s have the ign wire connected to key hot, & the CPS is set to look for the 12 volts when I start the car. So no matter what, the acc plug must be attached to the back of the radio.
FORMERLY MOONBOOTS
Old 06-05-2018, 3:12 PM
Hmmm, well mine didn't come with the Ign Wire/Ign Sense wire, so I'll either have to buy one or somehow make one.
Old 06-05-2018, 3:33 PM
Check Ebay maybe hard to make one on that type of plug.
Old 06-05-2018, 3:39 PM
Motorola Rear Accessory Connector Cable HLN6863B XTL5000 XTL2500 APX6500 APX7500 one on Ebay for $34.95
Old 06-05-2018, 3:46 PM
This one is less. There's a whole bunch, still new in the bag. Look for the least expensive. https://www.ebay.com/p/Motorola-Acce....c100005.m1851
FORMERLY MOONBOOTS
Old 06-05-2018, 5:38 PM
What I’m really curious about tho is, does anyone know what it means? What does Power Off No Delay mean? I’ve never seen or heard of that in all my years of CPS or radios...
Old 06-05-2018, 8:09 PM
Take a look in your codeplug at Radio Wide > Advanced II tab, under Power Off Keypress Duration (ms), you probably have a number plugged in there. PWROFF NODELAY means the Control Head does not support this feature. Set the value to zero and the message will not appear.
See the CPS help file for more information (there isn't much more information): Power Off Keypress Duration.
I don't know what CHs are capable. My 2 O5 heads are not.
Old 06-06-2018, 10:13 AM
That’s exactly what I have is an O5 Control Head, LOL. And I thought I knew CPS in-and-out. I just changed the value and I’ll go out and plug it in in a minute. Thanks for your help!
Old 06-07-2018, 11:06 AM
Thank you, that solved the problem!
Tags
astro25, motorola, xtl, xtl5000
