XPR 7550e programming problems
Pyro658
Communications Dispatcher
Central NJ
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Have you taken a fine screw driver or dental pick and lightly scraped the gold programming contacts on the side of the radio before connecting the programming cable? Do you get the Bing bong of the radio being discovered by windows once connected? Is this a gray market or other hacked type of radio? Thanks, TT.
N1GTL
CT
Your link points to SmartPTT's website. First, my condolences if you're using that product.
You don't mention your OS. MotoOnline has a USB driver file you can install. I have found that on some computers, I have had to run that USB driver installation.
Project25_MASTR
Millennial Graying OBT Guy
Texas
CPS 16.0 is the newest version. Been out for a few days now.
What’s the error you are getting and what is the setup?
K2NEC
What error are you getting? Is it a North America radio with the North America software?
Pyro658
Central NJ
The radio itself and cable are brand new. It makes the noise that connects. The error message after the wheel spins says it couldn’t communicate with the device. I have windows 7 professional if I’m not mistaken. I didn’t buy anything from there I just searched problems programming the radio and their site came up.
N4BSH
But, you could have an IP / IP route conflict.
Use ipconfig & netstat -rn to determine if you have an issue.
You're assuming he knows how to do all that......
I would try and use the latest CPS with Windows 10 if you can.
Although if you are getting the Bing Bong of windows recognizing the device and not able to Read then it seems to be an issue with the Radio and not the Software or Windows.
TampaTyron
Phoenix, AZ
There could be an issue with your computers wifi or ethernet port causing a conflict. I suggest disconnecting ether and wifi and trying again. Typically, the radio sets up an ethernet connection in the 192.168.10.x subnet. If you have another network connected in the same subnet, then you will have issues. TT
