XTS 3000 800mhz
tmartin111
Houston TX
Quick question, very unfamiliar with radio programming. Hopefully someone can help me out here. I'm currently in the market for a reliable handheld. My agency is on a VHF P25 phase 1 system. My question is if i bought a XTS 3000 800 mhz if it would operate on the same system or would it have to be a VHF P25. The XTS 3000 i'm looking at is flashed if this helps. Thanks in advance
parma,ohio
Better ask your Chief and ask the system administrator who's in charge of the system who would give the OK for the personal radio on the system he would have to give you a Radio ID.
parma,ohio
ok still have to check with the system administrator of the radio system he has to give you the radio ID to be on the system .
jonwienke
More Info Coming Soon!
VA
Unless the radio is dual-band, 800MHz will not work on a VHF system.
KE4ZNR
Radio Geek
He has already gave me the go ahead. I was just unsure if the 800 would operate on the vhf p25 system.
As others have said a radio designed to work on 800Mhz will not work on 150-174Mhz range.
Since you obviously don't even have a basic understanding of radio spectrum you probably need to stick with scanners.
Marshall KE4ZNR
KG4INW
Midlothian, VA
I suggest you get with the system administrator and go through an approved vendor to acquire exactly what you need then. That'll guarantee you end up with a reliable radio that will work right from the beginning without any problems. Too many variables when dealing with trunked subscriber units if you're just starting out.
jaspence
Michigan
XTS 3000
If you are truly wanting to be on a VHF system, there are VHF versions of the XTS 3000. The radio you are asking about will not work and is a very old, discontinued and unsupported, model. They are single band and will do conventional and trunked P25 as well as analog. The XTS series did not come in dual band format.
radioman2001
New York North Carolina and all points in between
To cut though all the noise here, if your department is on VHF which is 150-170 mhz an 800 mhz radio will NOT work. An XTS-3000 in any flavor will NOT work on P-25 Trunking Phase I. Your best bet is a XTS-2500 or XTS-5000 on VHF flashed for P-25 trunking. For conventional P-25 you will need a VHF radio, but a VHF XTS3000 will work with the right flash and firmware.
Checking with your system admin IF you are on a trunking system is a must as he can brick your radio if not aware of it. If you are on conventional P-25 the only thing you may need and you said you have it is permission from your department as the FCC holds the license owner responsible for any unauthorized use of any radio on that license.
KG4INW
Midlothian, VA
Looking at the database, it does appear your county is conventional and not trunked which makes things a lot simpler but still, I'd suggest going through whomever takes care of your radios to see what they can do to help you, even if you're looking to buy your own.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Actually, 9600 baud trunking (P25 CAI) was a flash-able option for the XTS3000. Wasn't very commonly optioned as the XTS5000 and XTS2500 were available by the time many agencies began migration from Type II to P25 trunking.
However, point still remains the OP needs a VHF radio and not an 800 MHz radio for his agency's conventional operations.
MTS2000des
5B2_BEE00 Czar
That part. And since the radio will be used for life safety, make sure it has been properly vetted by your radio shop/support team if it is a used radio. You are entrusting your life and the safety of others. Buying a used radio off eBay or any unknown source is a gamble.
There are many hacked up, jacked up, junk parts garbage pail radios from second hand sources. They may work fine for hobbyist or hams, but no way I, as a public safety systems support person, would EVER allow one on our system as the liability is too high.
Trunking radios may require specific options your system management uses. The advice to consult with (and go through their authorized procurement sources) is sound.
