Xpr8400 issue
BlueMoon2
Midlothian, VA
In my area, we have a local ham radio dmr repeater that I believe is probably a Motorola xpr 8400. Multiple users have reported the same issue on both time slots that the audio will cut out once ever 1-3 seconds and then come back in. It is ip linked to other sites, but no other site seems to be having this audio cut out issue on both receive AND transmit. I’m just curious what might be causing this issue?
N4KVE
PALM BEACH, FLORIDA
What kind of radios are the people with problems using? Does this only affect certain brands of radios? Are people using hot spots? Locally it seems to be the people using hot spots who are having/causing these kinds of problems.
RFI-EMI-GUY
There was some cheap chinese radio that would splill over and block both time slots. Could that be what is going on? Also it could be some plain old IM or desense problem.
BlueMoon2
Midlothian, VA
It doesn’t seem to matter what brand radio it is. We have hams using connect systems radios, I’m using an xpr 4550, another guy is using a tyt md-9600 and we are all noticing the same issue. When we go through a hotspot or to any other repeater, the problem goes away.
jfr
Walpole, Ma
Has the backhaul been looked at for BER or jitter? What is it using? Copper? Cellular? Microwave? Try pulling the repeater off the network and running it stand alone. You should be able to use the Local talkgroup to test if it’s happening while autonomous.
-JR
