APX8000 Scan Issue O5 head
firecop6284
Monterey CA
Our department has put into service the APX8000 mobile radios. I just updated the firmware and loaded our PD encryption. All the radios work perfect except one. When I build the scan list the radio traffic does not come through on any of the channels when the radio is scanning except the one its tuned to. The one thing I noticed that is different with this radio is that the Z showing it is scanning has a small period next to it that blinks. None of my other radios have that. It looks like Z. and the period blinks. Everything else is programed the same on all the other radios that work just fine.
Any ideas?
hakwye8518
Town of Islip, NY
from the user guide.
Blinking dot = Detects activity on the Priority-One Channel
during scan.
Steady dot = Detects activity on the Priority-Two Channel
during scan
rescueman433
Check to see if the mic hanger is grounded. I am betting that the HUB, Hang up box suspends scan check box is checked in CPS. Try grounding the hanger or unchecking the box.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Make sure you have the scanlists selected in the personalities and make sure your priorities are set properly (selected is what I tend to leave the primary so it'll consider the selected channel the priority).
firecop6284
Monterey CA
Thanks for the responses. I will have to check the grounding on the hand mic. I know the priority and scan list items are good to go. Its strange that all my other radios work fine except this one. Thanks again!
Thunderknight
Bletchley Park
I’d vote for the mic hanger/hub not grounded. Just had this exact problem and verified by touching the mic hub to the B post door pin. I prefer off hook scan anyway so I just reprogrammed it.
