CDM1250 Dead - Low Voltage Input?
jwoodtdor
One of our CDM1250 mobiles is dead. Power into the radio is 9.48 volts. Voltage at the fuse is 13.8. No known voltage regulators in line. Calling tech tomorrow. Is 9.48 too low?
jwoodtdor
Measuring the voltage at the plug at the back of the radio. The fuse holder under the hood is getting 13.8 volts on both sides of the fuse.
jwoodtdor
I confirmed that the low voltage is causing the issue. There is some sort of issue in the ignition detect circuit. Most of our newer installs are going direct to hot wire so there is no ignition detect issues. Every once in a blue moon, someone forgets to shut the radio off.
Sounds like you have some wiring issues. If you are getting 13.8 on both side of the fuse, you need to start working towards the radio looking for faults. Also, check to make sure your ground is good.
cmdrwill
So Cali
Yup. time to get out your test light as you need some load to make an accurate measurement. Bad splices and other discontinuity connections will test or read good with just a voltmeter.
Check the ground side also.
jwoodtdor
What we found was a single pole, quick connector (factory wire harness) that had corrosion from the engine coolant boil-over that happened the week before. Tech was able to clean up the wire terminal and get it back up and running in a few minutes. Thanks all for your help.
Put some heat shrink or some other protective covering over it if you're able to, and mitigate the issue in the future.
