Thegoodkid
- Joined
- Aug 4, 2016
- Messages
- 45
OK, so I have my XTS 5000 M2 7/800 MHZ (If that's important) set up for non affiliate for my local county. And it works amazing. My local county (Don't really want to say.) uses a single site system "C4FM" and the radio works just fine, but when I try to use it on the Hamilton county simulcast the radio misses transmissions about 95% of the time. Sometimes it will show channel activity, and sometimes... sometimes will unmute. I don't think the radio is out of aliment because I can pick up a county over 40 miles away, on top of that the radio will work on the Madison county simulcast just fine. (These systems are linked and have the same SID and NAC) If I'm in Hamilton county in between towers (So heavy simulcast distortion) the radio will work about 50% of the time.) I've checked my channel ID's with unitrunker 851.00625 & 762.00625 but no dice. I have also tried 851.00000 as well. My local county, which is on the SAFE-T system which is /\/\, Radio reference shows Hamilton county is also /\/\ but I don't believe that since the previous system was Harris EDACS (And I think they would want to stay with the same dealer.). One last detail, If I'm at home at AND BY THE GRACE OF GOD the radio unmutes, the radio will play audio like there's no tomorrow. If I can get it to unmute I can all but take the antenna off and it still works. I've had the radio about a month and still can't figure this out.
