trbo cps 16.0 build 827
hakwye8518
Town of Islip, NY
when I try to uncheck GNSS I get the following error#1100 application has encountered an error. if you continue to get this message, please contact customer service. Anyone else having this issue?
N1XDS
ÆS Ø
From what I am finding on a different forum error #1100 means the CPS is reading a codeplug that has been edited.
hakwye8518
Town of Islip, NY
The code plug in question was edited to go into the 70cm ham band. I tried the original before it was edited and a sample code plug and get the same message.
KR0SIV
Did you modify the codeplug or modify the CPS itself? If you modified the CPS that may be the issue.
com501
Since you have an MOL account, you can call and they will walk you through troubleshooting the error. That is what you pay for. Support.
hakwye8518
Town of Islip, NY
was hoping i could find the answer here instead of having to call, but it seems a phone call is in order. thank you for the help
K6EH
Anyone find the answer to this Error #1100 GNSS Issue?
I'm experiencing the same. On unmodified radios (as the earlier gentleman had an issue with a modified radio). Trying to check the GNSS box on some model radios, uncheck on other model radios. Error #1100 Application has encountered an error. Never had this before. I know there are bugs in all firmware and CPS, can this be one of them? Using CPS 16.0 here now. Which I know of some bugs, but not this one, if it is a bug.
N1GTL
CT
I can confirm this has nothing to do with a modified code plug. I just updated an XPR4550 to R01.12.17. I did a recovery to completely erase the existing program. I read the 4550 and right when I uncheck the GNSS check box, I immediately get the 1100 error.
I'm using version 16.0 of CPS and R01.12.17 was the final firmware release for Gen 1 radios.
I'm puzzled but this is just for a temp one day use so I don't have the time to deal with /\/\.
