FFEMT610
My HT1250 display screen has started having issues. For some reason, the backlight works perfectly fine, but the screen isnt showing any text, battery icon, etc. Anyone have any idea what may be causing this issue?
speedbird727
It might be worth a try to open the radio case and disconnect/reconnect the two ribbon cables that connect the board and the display / front buttons. Sometimes they just need to be re-seated.
Tech792
Central NJ
If the above suggestion doesn't work, the LCD probably needs to be replaced. They go bad after a while. They're not that hard to replace.
K2NEC
A single line on my LCD randomly goes bad for no reason. It seems like there is a 50/50 chance that when I power my radio that line of pixels will be on. It doesn't seem like it is temperature related or really anything else. Think this may be an LCD issue? Where do I go about purchasing a new LCD?
