XPR 7550e Programming Issue
jwpd416
I have a new XPR 7550e that I previously programmed using a PMKN4012B REV B 09/12. This is the same cable I am using now. I also updated my XPR 7550 and XPR 6550 today with it this cable with no problems.
When connecting to the radio I do not get the low high tone indicating it is connected and it will not read. However, when I disconnect I do get the high low tone indicating it has been disconnected. In addition to this when the cable is connected I do not hear any radio traffic through the radio until I disconnect the programming cable. When I connect my 4025A or 4050A lapel microphones I get both connect and disconnect sounds.
When connected to my 7550 and 6550 everything is working fine.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Disable wifi and unplug Ethernet cables to prevent IP conflicts. You can also lightly scratch the gold contacts with a sharp objects to cut through the oil/oxidation layer that may be on the contacts. TT
TampaTyron
Phoenix, AZ
Let me know how that goes for you...... no luck with erasers, fiberglass pens, alcohol wipes, etc. and I program trbo radios for a living. Hundreds to thousands of radios a week for a long, long time. TT
