band split
rich1125
our department went on a new channel it is 460.13750 can i use a 450-520 mhz uhf radio im not sure if im correct any help would be good thanks.
alcahuete
Antelope Acres, California
Frequency-wise, yes, the above answers are correct. However, is it analog, digital, etc.? If they went digital, then a standard 450-520 MHz analog radio is not going to work, for example. A DMR radio is not going to work for P25, and vice versa.
There is a lot more to figure out than just the frequency alone.
ecps92
Taxachusetts
Contact your Radio Shop [Techs / Company]
Too many variables
a. Is your Radio Narrowband
b. Did they go digital
c. Did they go from PL to DPL
With all the above, the question begins of
a. Does your Radio Support
We won't even get into the permission to put a radio on a channel licensed not by you [you need to ask and get written permission]
