First Energy P25 TRS
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
This thread is for discussion of the First Energy P25 trunked system.
First Energy: Allegheny Power Trunking System, Various, Multi-State - Scanner Frequencies
The First Energy P25 trunked system currently [as of June 2013] covers parts of Pennsylvania, West Virginia. This system covers portions of the First Energy territory including portions of the ex-Allegheny Power / Mon Power and Potomac Edison territories.
More info to follow.
mtindor
OH/WV DB Admin
Some things to know:
  • To monitor this system, you must have a digital scanner capable of monitoring Phase 1 P25. This includes the Radio Shack PRO-2096/96/197/106 models, the GRE PSR-500/600/800 models, and the Uniden BCD396[X]T, BCD996[X]T and Uniden HP-1 models as well as possibly a few older generation Uniden digital models.
  • If you'd like to help determine active sites in this system and their locations, you'll need a trunking application such as Unitrunker or Pro96Com and will either need to have a scanner capable of sending control channel data to a computer or will need a scanner with a discriminator tap. A Uniden Home Patrol with the Extreme upgrade will likely display useful information about trunked sites as well.
  • Thus far, this system is a VHF system. Most control channel frequencies are between 151-154 Mhz and from 173-174 mhz.
  • Some of the frequencies within this system are in the 152 mhz paging spectrum. Paging spectrum in certain market areas was acquired by Allegheny Power [and then re-assigned to First Energy]. The specific paging frequencies that may be in use on the system do not currently show up in FCC license records and may never show up there.
    Because of this, it is hard to pin down some of the sites that have 152 mhz control channels because they cannot be cross referenced [easily] with FCC records. However, with some careful sleuthing of the various sites, we can determine site locations. Of course, this will happen a lot faster if people work together to determine these locations.
Feel free to send me a private message if you'd like to help map out some of the unknown sites. Post your questions or findings here.
Note: This thread itself shouldn't turn into a How-To for how to use trunking applications to follow/map out a system. That is why I have mentioned that you can PM me if you are interested in doing so. I'll attempt to help as much as I can, within limits.
Thanks,
mtindor
OH/WV DB Admin
To: ScanWV
Is there any chance you could get me a pristine new dump on Site 1-195 ? I'm interested to see if the peer/neighbor information has changed.
Thanks!
From: http://forums.radioreference.com/we...irst-energy-project-25-trs-2.html#post1847193
ScanWV said:
Here is what I get when I decode the infor from my nearest site. They have been booming the past couple days since we have been without power. We just got it back last night.
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 89A
System Name : First Energy
WACN : 01DB6
Tower Number (Decimal): 1195
Tower Number (Hex) : T01C3
Tower Description : (null)
Control Capabilities : Voice,Registration,Authentication
Call Sign(s) :
Timestamp : Thu Nov 1 11:45:54 2012
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,151.00000,0.00250,0.00000,"Confirmed",0.01250,1
01,164.00000,0.00250,0.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0494","c",152.23500,"00-2864",158.16000,1,0
"00-0856","v",153.14000,"00-0000",151.00000,1,0
"00-1012","v",153.53000,"00-0000",151.00000,1,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
110,"T010A",89a,"01-3710",173.27500,""
135,"T0123",89a,"00-0850",153.12500,""
144,"T012C",89a,"00-0868",153.17000,""
1104,"T0168",89a,"00-0862",153.15500,""
1193,"T01C1",89a,"00-0838",153.09500,""
BM82557
Berkeley Co WV
First Energy: Allegheny Power Glengary WV site
Here's what I've got via SDR#/Unitrunker -
Glengary site - 001-035
NAC - 897
peers -
001-008 173.3750
001-009 151.8500
001-033 152.2400
001-193 153.0950
001-195 152.2350
Looks like the db doesn't currently list all of the peers or the NAC.
BM82557
Berkeley Co WV
First Energy: Allegheny Power Clear Spring MD site
Clear Spring MD site 001-008
NAC - 892
Peers -
001-006 173.2750
001-009 151.8500
001-033 152.2400
001-035 153.1250
001-045 153.6950
BM82557
Berkeley Co WV
First Energy: Allegheny Power Middletown MD site
Middletown MD site 001-033
NAC - 896
Peers -
001-008 173.3750
001-035 153.1250
001-045 153.6950
001-046 153.2300
mtindor
OH/WV DB Admin
BM,
Thank you for all of those peer site updates. I"ve updated the site neighbors listed in the DB for the above mentioned sites.
- Mike
wmbio
Cumberland, Md
Mike,
Im seeing a few unconfirmed TG's show up since Monday. Im trying to ID them as we speak. It seems the Midland tower has a few site neighbors and is hearing considerable radio traffic from the other sites.
73"
Wmbio
mtindor
OH/WV DB Admin
Mike,
73"
Wmbio
Do you have the capability of running Pro96Com or Unitrunker on the Midland site? If so, would you be willing to do so and get an updated list of site neighbors / their associated frequencies?
BM82557
Berkeley Co WV
Site 001-042
I first noticed this site in UniTrunker on 11/30. It is one of the peers of the Glengary WV site. It is in the RR database as an recent addition. I can "see" 153.5150 in SDR# but it is too weak for me to decode. It must be fairly close to my location or i wouldn't "see" it at all. Below is what Unitunker shows for the Glengary site. Any ideas as to where it is located?
mtindor
OH/WV DB Admin
Do you think you could be copying Linden, VA (Fauquier Co) ?
I suspect that is the site.
BM82557
Berkeley Co WV
That's quite possible. I can copy the Virginia STARS Hogback Mountain site which is located about 10 miles from Linden. Guess I'll have to have a little road trip to check it out with UniTrunker.
W3DMV
Gettysburg, Pa
Did some searching around regarding 153.515.
The only site currently licensed for operation on this frequency
is located at Terra Alta, Wv (Preston County)
The license for Linden, Va has a pending application attachment to delete
151.490 and replace it with 153.515. The license is WQOY898. See the
attachment at the FCC site explaining the request. It was submitted 11/2013 and has not
been granted yet..
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Watching the Weirton site with Unitrunker and saw affiliations to TGs 73, 65, 82. Lots to 73. No voice traffic yet though.
