Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Multi-State Communications Networks
Multi-State Communications Networks - The purpose of this forum is for discussion of trunked or conventional communications networks that span more than one state. They are local government or commercial in nature. For Federal or Military use the appropriate Topic Specific forum.
Old 12-04-2014, 5:52 PM
milf's Avatar
Careful, I CAN hear you!
Default Entergy P25 TRS ALIVE!
Well at long last the P25 Phase 2 TRS for Entergy has come alive. We need extensive monitoring of all the known original Entergy TRS sites for the new P25 system transition!
Info needed: CC's, ACC's, WACN's, Site numbers, Site NAC's, TG's - Both Slots if you can ID them.
APX6000XE
Old 12-05-2014, 12:56 PM
milf's Avatar
Default Entergy P25 discussion.
Now that the upgrades are complete, and the Phase 2 system is coming online, I am starting this thread for posting new discoveries regards the system. As always, any new sites, tg's etc you confirm, also submit them to the db. TY in advance!
APX6000XE
Old 12-09-2014, 11:24 AM
I was able to talk to an Entergy guy in Sulphur, La. this weekend and he had his new mobile installed and working. He was on talkgroup 155 and that's all it said on his display. His radio is an APX4500 with a full display. I came home and have been scanning for active control channels other than the one I know and have came up empty. I've ran Unitrunker on the old system control channel and TGID 155 has never showed up. I've programed everything from the FCC website into my scanner and came up empty. They were definitely digital I presume P25 Phase II, but I'm not finding a thing. Is there anyone else in southwest Louisiana that can assist or give guidance? Thanks.
Old 12-09-2014, 12:29 PM
safetyobc's Avatar
Here is what I got (already submitted to DB) when I ran Pro96Comm on the Monticello, AR Entergy P25 tower.
Running Pro96Comm on the Monticello, AR Entergy P25 Phase 2 tower I get the following information.
855.0375 d
857.9125 a
860.9125 c
System ID: 64F
RFFSS: 001
Site ID: 010
WACN: BEE00
Capabilities: Data, Voice, Registration
Tower Status: Connected
Flavor: Phase 2
Frequency Identifier Tables:
ID S Base Spacing TX Offset
00 1 851.00525 0.00625 -45.0000
01 1 762.00625 0.00625 30.0000
02 2 851.01250 0.01250 -45.0000
03 2 762.00625 0.01250 30.0000
04 1 935.01250 0.01250 -39.0000
05 2 935.0125 0.01250 -39.0000
Adjacent Site Information:
Site ID System Ch Frequency
101 (T0101) 64F 00-1577 860.8625
108 (T0108) 64F 00-0585 854.6625
109 (T0109) 64F 00-0681 855.2625
111 (T010B) 64F 00-0653 855.0875
112 (T010C) 64F 00-0941 856.8875
113 (T010D) 64F 00-0689 855.3125
134 (T0122) 64F 00-0505 854.1625
Old 12-09-2014, 3:14 PM
milf's Avatar
Hey Safety, any chance you could do an long time run on the site, and let it show all the active freqs, TG's etc? One full day should be enough logging to get a good idea on it. An weekday would probably be the best timing as that is the busiest time, other than during storms lol.
APX6000XE
Old 12-09-2014, 3:25 PM
safetyobc's Avatar
I will try to get it tomorrow.
Old 12-09-2014, 3:58 PM
I did not try 900, I'll look there.
Old 12-09-2014, 7:32 PM
milf's Avatar
Entergy gave up its 900 MHz TRS long long ago, and now only operates on the 800 MHz system for trunking, and some UHF Ops.
APX6000XE
Old 12-10-2014, 3:03 PM
safetyobc's Avatar
Here is what I got after running Pro96Comm for several hours today on the Monticello tower (WPPD430)
channel....freq......usage..type
00-0645 855.0375 id data
00-1105 857.9125 ad
00-1585 860.9125 c control
02-0644 855.0375/0 v
02-0645 855.0375/1 v
02-1104 857.9125/0 v
02-1105 857.9125/1 v
TGID's Found
461 = SE Arkansas Operations (Monticello, Warren, Dermott, etc.)
459 = Unidentifed Ops (Unit calling Malvern, AR office)
491 = Operations of some type (central AR area sounds like).
408 = Unidentified
1 = Unidentifed
Seeing WPPD430 callsign being broadcast on 855.0375 - Channel Grant Trace tab.
Captured 30 unique Radio ID's.
Old 12-10-2014, 7:19 PM
milf's Avatar
Awesomeness. Will add that and more data Saturday.
APX6000XE
Old 12-22-2014, 10:29 AM
here's what I get from unitrunker this morning while monitoring the Benton, AR site
Callsign WNZP817 (license site 2, 34-33-26.0 N, 092-39-16.0 W)
Modulation C4FM
NAC 644
RFSS 001
Site ID 045
SysID 64F
WACN BEE00
bandplan identical to what safetyobc posted except I think he had a typo; 851.00525 shows to be 851.00625 here
Channels:
LCN Freq Bandwidth
00-0585 854.6625 12.5 (Control)
00-0861 856.3875 12.5
00-1405 859.7875 12.5
00-1501 860.3875 12.5
00-0860 860.3875 12.5
02-0861 856.3875 12.5
02-1404 859.7875 12.5
02-1405 859.7875 12.5
02-1500 860.3875 12.5
02-1501 860.3875 12.5
Peers:
Site Control Freq
001-035 00-0653 855.0875
001-036 00-0937 856.8625
001-041 00-0485 854.0375
001-044 00-0613 854.8375
001-049 00-0589 854.6875
001-050 00-0725 855.5375
001-066 00-0741 855.6375
Old 02-18-2015, 3:00 PM
Using SDR#, I was able to capture a waterfall and .mp3 audio from an ENTERGY site nearby. The frequency is 854.162.5 NFM 12000 BW.
If anyone needs it, let me know.
Old 02-23-2015, 9:11 AM
almost all the radios have been programed for louisiana, then we will distribute them
"Once we understand that all we know, is that we dont know, only then we will know everything." -Davis
Old 03-09-2015, 2:01 PM
Just curious if there are any sites that are planned in the DFW area, this system appears on RR in my home county yet I have not seen any sites in the North Texas area. I am guessing the this system was blanketed by default for statewide?
Stephen
Old 03-21-2015, 12:10 PM
KE5TLF's Avatar
Yeah how about setting the actual counties Entergy services.
(hint: it's the same as the analog system......)
....and just to be thorough...
Entergy Arkansas - Service Area
Entergy Louisiana - Parishes
Entergy Mississippi - Service Area
Entergy Texas - Service Area
Old 03-21-2015, 1:09 PM
I just noticed today that the Entergy tower in Forest, LA has changed site id to the P25 system. It's now site 2-34 with the same control channel.
Old 03-23-2015, 9:00 AM
milf's Avatar
Please make submissions the usual method guys n gals. TY.
APX6000XE
Old 04-11-2015, 10:41 PM
milf's Avatar
OK, so far we know Zone 1 is all of AR. Zone 2 thus far covers portions of LA, and at least one site in Central MS.
APX6000XE
Old 04-11-2015, 10:43 PM
milf's Avatar
Much more monitoring is needed so we can see just how far along the system is, and we can start deprecating the analog Smart Zone completely.
APX6000XE
Old 08-20-2015, 10:13 AM
k5wc's Avatar
Hello all I just upgraded to a new scanner and while working through the learning curve I've been monitoring Entergy. Just on the fringe of LR site 49 and site 50 with my inside antenna. Not sure where site 50 is located. I can hear site 47 on 855.5625. It's not listed in the DB but will submit.
TGID's
423 AR Central stations calling control and DOC on this tg
450 DOC
462 Mobile Data?
189 Wharehouse or distribution
456 unidentified ops talking about pulling wire
481 possible Stuttgart area?
475 ?
477 possible Searcy area?
1 couple guys talking referring to it as talk group 1
408 Radio Tech was testing and rotating all channels on Yellville site 60
