Go Back   The RadioReference.com Forums > U.S. Regional Radio Discussion Forums > Multi-State Communications Networks
Multi-State Communications Networks - The purpose of this forum is for discussion of trunked or conventional communications networks that span more than one state. They are local government or commercial in nature. For Federal or Military use the appropriate Topic Specific forum.
Old 10-26-2016, 10:22 AM
AC0RV's Avatar
Default Trip
Ok its trip planning time again. I working on a trip to Louisiana.
My route is From Park Hills, MO to Boglusa. I will travel via Hwy 32 to I-55 @ Ste Genevieve Co MO to Fluker (Tangpahoa parish),La. From there will Travel via La 10 into Bogalusa, La.
Need any UIDs,etc for the MOSWIN,AWIN, TACN, MSWIN, and the LWIN. ( I know I can get the TGIDs and frequencies in RR Database). DMR info (ie tgids,uids, etc) and of course and county info that is not covered by in RR Database.
The counties will be traveling in are as will travel in are as follows
MO Ar/TN MS MS La
St Francois Mississippi Tate Copiah Washington
Ste Genevieve Crittenden Yalobusha Lincoln
Perry Shelby Co Tn Grenada Pike
Cape Girardeau Holmes
Scott MS Carroll La
New Madrid DeSoto Madison St Tammany
Pemiscot Panola Hinds Tammany
So any help in this project would be deeply appreciated a lot and very sorry for this being a
lengthly post.
The only way into heaven is through Jesus.
David F AC0RV
Skywarn # M187201
Old 10-28-2016, 8:13 AM
AC0RV's Avatar
I still need the help
Big thanks.
David F AC0RV
Skywarn # M187201
Old 10-28-2016, 1:04 PM
DaveNF2G's Avatar
If UIDs are known, then you should be able to find them in the Wiki. If there are none listed, then maybe the information is not available yet.
David T. Stark
NF2G WQMY980 KYR7128
