PowerSouth Energy Cooperative Trunk System AL/FL
bravo14
Polk County FL
Since DMR went public release I've been working on this system PowerSouth Energy Cooperative Trunking System, Andalusia, Multi-State - Scanner Frequencies
I'm using my BCD536HP
Site 11/28 are comfirm on LCN and Color Codes. Past few months been picking up different sites and Color Codes while bands are open up. Some sites are not correct in the DB. Appears to be 29 sites total for this system.
I made a spreadsheet and made it to PDF to show what I have so far.
Using PSR800 & DSDPlus
On Neighbor sites I use my psr 800 and DSD Plus to get the Neighbor info. If signal is good enough to decode.
If anyone in AL or FL can help to put this together be great :) I believe the Control Channel seems to be LCN 1.
Site12 has 2 same freq. Holmes County appears to be the correct site?
Site 19/20 on the DB seem not to be correct.
Site 8 seems has 2 from different areas 1 from AL the other FL I believe the in FL is correct.
Site 901/903
903 appears to be site 3.
Site 901 possible be site 1?
bravo14
Polk County FL
This morning bands were open up and got a new pdf file made. Here is a update.
bravo14
Polk County FL
Here is another update.
  • PowerSouth Energy Cooperative (Gulf Power) Trunking System 2.pdf
millam
Old Radio Guy
This is what FCC shows for licensees for powersouth.
bravo14
Polk County FL
Since last night I have updated my List. I noticed some new sites never seen before. When bands are open I'm using computer and DSDPlus to get Color Code Sites Neighbors List. System too slow to use the LCN or LSN.
Site - County of State - Freq - Color - Neighbors List
Site* New finding
Site 1
Site 2 Baker FL 461.6000 Color 0
Site 3 Conecuh AL 451.0375 Color 0 NL 10 18 20 21 29
Site 4 Clay or Henry AL or Escambia FL 452.8500 Color 1 NL 12 25 26 27 Possible Escambia Site?
Site 5 Chilton or Washington AL or Escambia FL 452.6000 Color 0 7 15 18 19 24
Site 6
Site 7 Clarke AL 451.1375 Color 0 NL
Site 8 Montgomery AL or Walton FL 451.0250 Color 1 NL 6 21 25 (27?) Possible Walton FL site?
Site 9
Site 10 Walton FL 464.7625 Color 0 NL 2 11 12 28 29
Site 11 Bay FL 452.6250 Color 0 NL 10 12 26
Site 12 Holmes FL 451.6000 Color 2 NL 4 20 25 26 29 (I've updated to RR waiting for to be listed)
Site 13
Site 14
Site 15
Site 16* Baldwin AL Monroe AL Jackson FL 452.2000 Color 1 NL 3 7 18 19 22 (possible just a AL site not FL?)
Site 17* Chilton AL Washington AL 452.5500 Color 0 NL
Site 18 Santa Rosa FL 451.0625 Color 0 NL 2 3 7 19 21
Site 19
Site 20 451.0250 Color 1 NL 2 12 21 25 29 Appears to be a FL Site? RR shows AL site 20
Site 21 Covington AL 451.7750 Color 0 NL 3 8 18 20 25
Site 22
Site 23
Site 24
Site 25
Site 26 Jackson FL 451.5500 Color 0 NL 4 10 11 12 28
Site 27
Site 28 Bay FL 451.7500 Color 0 NL 10 11 12 26 29
Site 29 Walton FL 452.7000 Color 3 NL 2 10 12 20 28
bravo14
Polk County FL
This past Sun night into Mon morning I was picking up some new sites and got more neighbor site info. Here is a PDF file. If anyone can help to put this together. I do hear talkgroups on/off on this system. I am using dsdplus for info and sds200 to look for certain channels & control channels. DSDPlus doesn't work with Con+ good to detect what LCN/LSN numbers. I do notice when a Cntrl Ch shows up and do LCN finder on the sds200 it goes to 1. Not sure if that is all defaults to 1 for C/C....
  • PowerSouth Energy Cooperative CON+.pdf
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Nice job, @bravo14
Based upon what is in the DB, and especially what is in your findings included over time, here is a map that I think is probably accurate.
I have a feeling that Site 4 is Capps AL (Henry) but I guess could be Ashland AL (Clay) -- although I really think Site 4 would be Capps.
And I agree the DB has some stuff wrong -- at the very least 19/20.
Map: PowerSouth Energy Cooperative - Google My Maps
Maybe the map will be of some help to ya.
bravo14
Polk County FL
Here is a pdf file for sites & freq this is how I figure out instead looking up for each state.
  • PowerSouth Notes for sites and info.pdf
bravo14
Polk County FL
On post 10 pdf I forgot to add sites 4 5 16 20 here is the update in green on those sites.
  • PowerSouth Energy Cooperative CON+ Update 482020 1120.pdf
mtindor
OH/WV DB Admin
Site 4: either Capps AL (Henry) or Ashland AL (Clay)
Site 5: either Chatom AL (Washington) or Atmore FL (Escambia)
Site 16: either Foley AL (Baldwin) or Mexia AL (Monroe)
Site 20: Paxton FL (Walton)
I believe Site 4 will be Capps, that Site 5 will be Chatom, and that Site 20 is Paxton.
Unsure about Site 16. The CC for Site 16 is 452.200, which is on multiple licenses. But given the neighbor list for Site 16, it can be narrowed down to the two sites above based upon CC frequency of 452.200 -- Foley AL or Mexia AL.
And remember, I'm in Ohio. I'm not monitoring any of this system. I'm just interested in multistate power company systems and like to create maps and help figure out locations. All of the legwork is basically done by you and anyone else down that way who feels like participating in the sleuthing.
bravo14
Polk County FL
@mtindor What I was doing with the sds200 is I have FL & AL setup conv and scan & record and compare site number shows up on that freq and compare my list I have. Before DMR public release there was 3 sites listed 9xx like 901 should be site 1. I seen 901 &903 than one night bands open up and site 3 came up with same freq as in 903 than I look further into it and found it was site 3 not 903. Guessing Site 4 might be Ashland AL. When I go west one day towards P'cola I'll see what comes up with Escambia, Santa Rosa, Okaloosa, Walton FL sites. Once awhile I'll go DeFuniak over night if there is a disc golf tourney.
bravo14
Polk County FL
@mtindor I have to look into site 8. I think I have some recordings if so I'll look at freq see who it really is. I think it is paxton might be 8.
bravo14
Polk County FL
@mtindor I think your right on site 8 & 20. I was looking at some site neighbors and went by that.
Here is 2 updates of the pdf 041020. Site 21 on the DB is incorrect I know for sure.
  • PowerSouth Energy Cooperative CON+ 041020 1217.pdf
  • PowerSouth Notes for sites and info 041020 1216.pdf
bravo14
Polk County FL
About a hour ago I went to see if I still had something from years ago. I notice I had 1 file I was able to compare. Site 4 is Capps. I updated 2 pdf they are in dark green. I did sites 4 5 6 26. I have not submitted the info to DB yet waiting for awhile and than send 1 submit instead 5.
  • PowerSouth Energy Cooperative CON+ 041020 2215.pdf
  • PowerSouth Notes for sites and info 041020 2212.pdf
mtindor
OH/WV DB Admin
@bravo14 You say "Site 21 on the DB is incorrect I know for sure"
How do you know that for sure? Site 21 451.775 is only licensed to River Falls and the site neighbors make perfect sense for it to be River Falls.
bravo14
Polk County FL
I pick that site up quite abit like this morning. I went through all my lists the past few days. River Falls should be 451.3000 451.7750 452.00000 452.3000. Not sure why these freqs 451.1300 451.4250 452.025 452.850 (are in site 21) they are difference license and different area.
