Gariac, thank you for thinking my idea is nuts. I like honest feedback. I have a question though, can you do multilateration with your 4 dongles feeding virtual radar server? I just don't know that much about VRS.
Com501
- To do this you need an antenna, receiver, Computer (or single board computer), and an internet connection.
- Extra antenna's may not help if they are not tuned to 1090 Mhz. The receiver dongles that Nooelec sells come with pre-cut 1090Mhz antennas however they are not what you would install at a radio site. The receivers / dongles run about 18$
NooElec - SDR Receivers - Software Defined Radio The antenna I use I am getting ready to replace. Right now I use a DPD 1090 antenna you can find it here:
DPD Productions - VHF Air/Aviation Band, FBO Base, ACARS & ADS-B (SBS / RadarBox) Antennas for Commercial & Hobbyist Applications. I am going to get an antenna that has a built in bandpass filter and amplifier once the design is completed. Read more here:
Antenne Active PCB 1090 MHz - 1090 MHz Active PCB antenna - F5ANN is still working on the design.
The raspberry PI now has software that will let it feed planeplotter directly with no need for anything else other than the Raspberry Pi and receiver dongle... total cost minus shipping, antenna, and internet connection is now around 45$. The Raspberry pi does need to be programed with the location of the station.... considering location is a key in multilateration!
Elko is a great spot, It wouldn't help me any but it would build out the network that exists in Colorado and Utah! To see the current locations of aircraft on the planeplotter network look here, Note the red dots are the multilateration generated locations, you will see them in colorado / eastern utah and in san francisco during normal hours of the day
PlanePlotter from COAA This link shows where all the users are currently located at:
PlanePlotter from COAA You can see the big hole between truckee and salt lake city, another reason why Elko is a great spot!
Cedar City would fill in southern UT/NV considering there already are a few stations in lost vegas.
Ok time to go my battery is dying on my laptop... fail.
