I took my BCD396XT out for a drive last night, and I was occasionally picking up communications on the dispatch channel... so that confirms Markscan's post.
I'm getting error rates between 40 and 60, and the auto decode threshold setting sits at 7 and bounces up to 11. Occasionally, I'll get low error rates and clear transmissions, which seem to be more common from the patrol cars.That might just be a coincidence, though.
BTW, just to give a frame of reference, I'm running the 1.10.00 firmware, and my P25 Adjust Mode and Adjust Level are and always were 11 and 50, respectively. I believe that Uniden advises to leave the latter at 50, but I suppose I could mess with the P25 Adjust Mode and see if that does anything.
Obviously something changed, but what? Is it possible that there is an underlying reason for the SID change that is causing this problem for us?
