Uniden BCD536HP & Jersey City PD/FD
Danny37
New York City
Picked a bcd536hp scanner recently and it can't seem to pick up jersey city PD or FD on their P25 trunking system. One in awhile it picks up a transmission but then it locks on the channel and no audio passes through. I'm not out of range as far as I know, what could be the problem?
t13one12
NJ
Far from an expert, so no disrespect intended, but isn't Simulcast distortion more common on multi-site systems? This system only has a single site.
Danny - I think I recall having similar problems a few years back. I followed the steps on this site to manually adjust the decoding threshold and that seemed to work wonders for me. Maybe give that a shot?
https://wiki.radioreference.com/ind...ment#Manually_Adjusting_P25_Decode_Thresholds
WQPW689
Palm Beach Co., FL
I was puzzled about this as I'm currently in Bayonne and hadn't been listening to them but when I turned them on with a 436, I got dead silence for an hour. Never had that occur before. I checked back and then followed t13one's advice and turned the P25 Threshold to Manual, and I'm getting them OK again.
OP, try his suggestion and see what happens.
I have to stress, I didn't change any values, just switched to manual threshold.
coolrich55
connecticut
I have a PSR 500 and JC comes in great at all locations I've been to mostly along the river on NJ and NY sides. Furthest out in NJ was probably Rutherford or Fort Lee. And near times square. I use software for all my scanners and the 500 is set for P25 auto.
coolrich55
connecticut
That's very possible unfortunately.
I miss the simplicity of analog conventional signals.
No kidding right? The analog trunked systems aren't bad either but the digital trunked ones are a pain sometimes. One thing to keep in mind also when it comes to P25 not all scanners are created equal.
Danny37
New York City
I used to listen to jersey city before they went digital man what a madhouse it was. Reminded me of Brooklyn in 80s. Haven't got around to messing around with settings yet but I'll definitely change the threshold setting.
Just to manual? No preset number?
ansky
NJ
Where are you located? That would help determine if simulcast distortion is really the issue. I live 10 miles away in West Orange and I can hear JCFD and JCPD loud and clear, so the signal definitely gets out. If you're located within the JC city limits then I could see distortion being a potential issue.
Danny37
New York City
I'm in Queens by the Queens center mall.
ansky
NJ
Ok, so you're likely too far away to be experiencing multicast distortion. The issue is likely that the tall buildings in Manhattan are blocking the signal into your area. So you're probably just getting poor reception.
ten13
ten13
We assume you have the "Law Talk" and "Fire Dispatch" services selected, correct?
