mdsxfire
EDBM
I just recently programmed in the NJSP Motorola system in my scanner and am listening to Troop B 5comm car2car fleetwide parkway central turnpike central and a few others. The first few days all transmissions were clear with full signal on the scanner, with the exception of some slight static from the cars connection to the system but the bars on the scanner always full. Tonight ( now it is rainy and cloudy) when on the control channel is scanning its bouncing between 4-6 bars, no big issue. My issue is a trooper will key up on troop b 5 comm loud and clear full bars then another trooper with talk right after same TG and is all static and go from 6 bars to 1? Shouldn’t the received signal be the same strength as the control channel freq? Could it just be a few of the freq pairs are more adversely affected by the inclement weather?
