Oh, I get what you mean. I thought the holdup was about the now non-existent Santa Fe Public Works TRS. It's still showing up in the database at
Santa Fe County, New Mexico (NM) Scanner Frequencies and Radio Frequency Reference &
Santa Fe Public Works Trunking System, Santa Fe, New Mexico - Scanner Frequencies Is there anything holding up removing it?
There's no doubt that 860.2375 is part of the Santa Fe Public Safety
Santa Fe Public Safety Trunking System, Santa Fe, New Mexico - Scanner Frequencies TRS. It's on the same license of WQOX375 for this TRS, and they are the only licensee in all of New Mexico on 860.2375 MHz. While I was in Santa Fe it was active with Public Safety related traffic, I was just so busy putting together business TRS's that I did not have the time to see TG's roll over on this frq from the other frqs in the TRS. The next time I am in Santa Fe I will check to confirm it is on this TRS and advise you.
855.4875 is on the same shared license of WQBI580 with the other Santa Fe Public Safety TRS frqs, besides the WQOX375 frqs, and the only other licensee in the state is Carlsbad, about 245 miles southeast of Santa Fe. 855.4875 was also active with Public Safety related traffic, I did not take the time to see TG's roll over on this frq from the other frqs in the TRS. I will check it out next time in Santa Fe too and advise you.
Until my trip back to Santa Fe, maybe other listeners can keep an eye on 855.4875 & 860.2375 especially in case they turn out to be one of the two missing control channel frqs, since I found two on my trip there this month, now listed as 857.2125 & 858.2125, and there are sometimes four control channels in a Motorola TRS.
Accuracy is a good thing! Thanks for keeping it that way. I am grateful for the work you do as moderator. You are the backbone of RR.
Good monitoring, Mick
Mick, I understand that you submitted the information; however, I want 100% accuracy when it comes to the DB. I'm looking for someone to run unitunker to get the current channel lineup.
