Hello, I'm a newcomer that needs info on how to download data to my scanner. I've done the 3 things that the link said to do and I'm at a dead end. 1. became a premier member. 2. got Pro Scan software. 3. have a BCD396T. What's next?
The first thing to do is open a database file. Click on the database menu and choose "Open" or "New". Choose "New" if you don't have an existing ProScan database file on the hard drive.
Now go to the database menu again and click on "Imports" and then "RadioReference Web". The RadioReference Web form should come up. Now type in your RadioReference login info and click the "Connect" button.
Now you should be able to select the country, state / providence, county, etc... Once you find the system to import click the "Populate Tree" button and the tree will fill up with data.
Click on the box to check the item/s to import.
Click the "Import" button. The select items should now have been imported.
Keep in mine that the 396 is a single site scanner so if importing a trunking system and more then one site is selected, a message will come up telling you to only select one site.
