Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 03-16-2011, 5:51 PM
Default 396 XT Display
Looking to have the multicolored display stay illuminated (in any color) once the unit is turned on and plugged in. Seems very hard to read without backlight. Can this be set at startup? Is the only way to illuminate by pressing a key?
Can one set the unit so that when a frequeny triggers the display lights up?
Newbie with bad eyes.
Old 03-16-2011, 10:12 PM
mdulrich's Avatar
The lower left button will toggle the backlight on and off with a short press. This is the same button to power the unit on and off. In the main menu under 'Settings' the first option is 'Set Backlight', under that is 'Set Mode' with options of '10 sec', '30 sec', 'Squelch', 'Keypress', and 'Infinite'. The other settings for the backlight can be found in the 'Set Backlight' menu.
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
Old 03-20-2011, 9:24 PM
Default Thanks
Thanks for the reply. I'm good with the settings, although I. Can't seem to figure out what "infinite" setting does. Really trying to get the display to stay Illuminated from the time I turn it on.
Old 03-21-2011, 7:48 AM
Originally Posted by jopfeiff View Post
then use the infinite setting then to always stay on
thats what it is used for till you hit the backlight key if you wish to shut it off
Old 03-21-2011, 8:55 AM
DaveIN's Avatar
Founders Curmudgen
This may also help: Settings < UnidenMan4 < TWiki
Old 03-21-2011, 11:26 AM
Default Thanks again
I think it was user error as I wasn't saving the config before i sent the informaiton to the scanner. Thanks to both of you for the replys and the reference to the guide!
john
Tags
396xt, display, startup
