Michelle0H
- Joined
- Apr 13, 2004
- Messages
- 102
Hi. I'm looking for a new scanner and hope that the BCD436HP will be one that will do all?
I currently own a Pro-97 and a Pro-93, but these aren't much use in my area that has gone mostly digital. Greene County, Ohio (OH) Scanner Frequencies and Radio Frequency Reference and Montgomery County, Ohio (OH) Scanner Frequencies and Radio Frequency Reference
I would like to be able to listen to Rail, which I assume I can use the Pro-97 for just fine, but would I need to if the Uniden is just as capable? (No tracks in my area, but when traveling.) Would also appreciate a good tuned antenna recommendation for rail frequencies. And, while I'm at it, is there a programming cable that I can use that will connect with a Winbook? (Apple user with Starrsoft saved to flash drive.)
What are the chances that the Uniden will be out of date before long? I would like something I will be able to use for several years.
So, aside from Xenia PD which is encrypted, would this scanner be fairly easy to use and receive what's in my 'hood?
