Bad reception of what??
Larry
Where are you located? No one can help unless we know your location. Scanning activity, reception, and requirements vary widely with location. Regards
Hyde park ny Dutchess County Trunked Ed system From the tower across the river and the mount beacon tower
Why don't you put each site in a different bank. Then you can use them alternately to see which picks up the traffic the best. Are you using the antenna that came with the scanner? If so, try it at its shortest setting for the frequencies, that is, pushed all the way down. It could be the old terrain thing, new buildings, trees that have gotten larger over the years, the sites themselves deteriorating over the years. Or, just the radio losing sensitivity.
HTH,
Larry
NYCOMCO (EDACS) Trunking System, Various, New York - Scanner Frequencies what other digital system are you comparing it to?
Has the BC898T ever performed well for you?
Are you certain it is programmed correctly?
Do you hear several beeps after each transmission?
The antenna connector on the back is a BNC type with a fork type center socket. Sometimes it can spread open with use and make poor contact with the antenna. Gently bending the contacts together slightly will cure that problem. If you don't know what I am talking about it may be best to get someone with experience to help.
At about 25 miles from the Walker tower my BC898T has no problem tracking the system. Hyde Park and Dutchess 911 are received without distortion here. I have not experienced a decline in sensitivity in my 10 year old BC898T and had not heard of reduced sensitivity being a common problem with this model.
You are much closer to the tower than I am. There should be no difficulty receiving the system at your location under normal circumstances.
YES yes I do not always but sometimes maybe 20 percent of the time
This being the case, make sure that you program all of the frequencies for either site in each bank channel according to the numbers to the left of the frequencies. One site has nine frequencies, the other has three. This should make listening easier.
Larry
