Greetings, I currently am looking for a recommendation on a handheld analog scanner. I have a 436HP that I do all my digital listening on but want another for air and older analog systems here locally. Any recommendations? Could be an old model off ebay or new one also. Thanks in advance!
IMHO there is no reason not to use the BCD436HP also for Air Band listening.
I have one too, and it can hold thousand of channels in its memory, thus its easier to program many analog systems in it.
Moreover, it has the recording function built-in (I use it heavily).
Consider also that an analog scanner has not as much memory as the 436, and cannot record the audio on the internal microSD.
I have a UBC125XLT too (the European version of the BC125AT), but it can hold only up to 500 channels in its memory and, in order to record the audio of any channel, separately from the other channels in monitoring, it is needed to feed the audio from the scanner to a PC running a software like Scan125, thus it would be impossible to use it as a handheld...
Regards.
