Chirp frequency images
theborg
Good evening
where is a good resource to download compiled images for chirp for my boafeng.
i am specifically looking for one for canada.
thanks
jonwienke
More Info Coming Soon!
VA
You don't.
Images are not compatible across different firmware versions. If you were to load one for the wrong firmware version, you can brick the radio.
Proper procedure is to read the image from the radio, import a CSV file with your preferred channel list, then write back to the radio and save.
theborg
thanks but where do i get the cvs files from
You don't.
theborg
i thought like DMR plug files, there would be a list of repeater frequencies in each city
kayn1n32008
ØÆSØ
Sector 001
You can down load from repeaterbook(ASSuming) you are looking for amateur repeaters. There would only be premade lists if someone had already made one.
jonwienke
VA
Also, investigate the Radio / Import From Data Source menu in CHIRP...
KK4JUG
GA
I'm not familiar with Canadian law but I think that if you're gonna talk on those frequencies, you'll need a license. If not, you'll probably have more versatility using a scanner.
kayn1n32008
ØÆSØ
Sector 001
Take the time to actually learn how to use the software, and learn how to enter the data in the correct spot. Nothing worse than newbies wanting everything spoon fed. A Baofeng only holds like 128 channels, and once you get a rhythm, programming is a snap.
I built a complete codeplug with every UHF ham repeater in Alberta, plus ham simplex, plus GMRS receive only, plus LMR receive only, plus all the DMR repeaters in western Canada with talk groups in a few days, working on it for an hour every day. While it did take some time, I learned the software. Same thing for my Kenwood dualband mobile and DStar radio.
Pretty much every radio service needs a license in Canada except GMRS/FRS.
