Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 05-13-2017, 6:08 PM
Unhappy Alinco DJ-X2000 problems connecting to PC via RS232
Hi, first time poster so be gentle,
I have owned this scanner for a couple of years and never had any luck connecting it to a PC. I assumed it was something to do with it not liking RS232-USB adaptors or the ERW7 USB cable. I recently got a toughbook, which is graced with an RS232 port so i thought here's my chance and have had another go at getting a PC connection working but with no luck. my setup:
panasonic CF-19 toughbook running Win7 pro
ERW4 2.5mm jack to RS232
Alinco DJ-X2000 scanner
Alinco DJ-X2000 clone utility
i have tried:
in device manager i set both COM1 and COM2 to match the settings given in the RS232 spec sheet:
Data bits 8
Parity None
Stop bits 2
Flow control hardware
I have tried both ports with FIFO on and with FIFO off. I have tried all 3 baud speeds the scanner offers
when I try to write from the scanner to the PC (clone>write) it says 'sending' for a few seconds then returns to the menu
when i try to 'read all data' using the software utility, it fails and i get the message 'A Communication Error Occurred: 1.' this also crashes the scanner and i have to cycle the power
doing both at the same time will result in one or other or both of the above behaviours
If i try to use Chirp (great software with other radios, esp Baofeng UV-5x variants) '>Download from radio' option, a box comes up with dropdowns that correctly identify an alinco radio on COM1 but Chirp doesn't appear to know of a DJ-X2000 model. attempting to clone anyway fails immediately, but the scanner display says 'clone interface err' and the scanner is crashed/frozen and only cycling the power fixes this (so there does seem to be the potential for 2-way comms between scanner and PC
I have tried to access the scanner or determine it's com port behaviour/settings with hyperterminal but without success (probably cause i don't know what to do with hyperterminal besides change COM port settings.)
it's such a great scanner, but programming through the hardware interface is laborious. any help would be greatly appreciated.
Tags
alinco, com ports, dj-x2000, rs232
