Hi all, so long story short, I have been hosting my local PD over the interwebs for about 7 years now. It is the only station that I have programmed into my scanner and I set it and forget it. The scanner is a RS PRO 433 and is still brand new as once I got it broadcasting, I never touched it again... So anyway, my local PD just went all digital so now this scanner will no longer work.
The new system is a P25 phase 2, system. I am now in the market for a digital scanner that will provide P25 Phase 2, that wont break my bank. I do this out of courtesy to my city residents and dont really have $450 bucks or more to spend on some crazy scanner that I will only use to broadcast my local PD on.
Anyone know of any or where I could look or specific models, that are fairly inexpensive, digital and can handle P25 Phase 2?
*If this is the wrong area, please move, I looked and couldn't find a better area**
Hi therick
Looking at your
county in the database, it does not appear that it has been updated as to which system your city moved to. If it was to a P25 Phase II system, can you confirm it was the statewide system?
https://www.radioreference.com/apps/db/?sid=7127
The system is capable of Phase II operation, but at present, the vast majority of the submitted talkgroups appear to be P25 Phase I, but that could change at any time, and if you don't know the talkgroups your city moved to, then to be safe, you probably need to look for a Phase II capable scanner. (If you knew,
for sure, that your city is Phase I & no change is planned in the foreseeable future, you would have some cheaper scanner options.)
Phase II capable scanners include:
Uniden
Uniden BCD436HP (Handheld)
Uniden BCD536HP (Base/Mobile)
Uniden BCD325P2 (Handheld)
Uniden BCD996P2 (Base Mobile)
Uniden Home Patrol 2
This model can be used as a desktop scanner, or with optional available mounts, used in a vehicle. While not really designed as a ‘true handheld scanner’, it does run on batteries and can be carried in a coat pocket or in a small belt tool holster.
Whistler
All of the scanners in this group can receive P25 Phase I & P25 Phase II signals. These also can utilize a free upgrade for receiving DMR systems.
WS1088 (Handheld) Has keypad.
WS1098 (Base/Mobile) Has keypad and a detachable head for mobile installations.
TRX-1 (Handheld) Has keypad.
TRX-2 (Base/Mobile) Has keypad and a detachable head for mobile installations.
The TRX-1 & TRX-2 also have an available free upgrade to enable reception of NXDN systems.
Previous Whistler models that are also P25 Phase I & P25 Phase II capable, also have a free DMR upgrade:
WS1080 (Handheld) (Same as the WS1088, except lacking the numeric keypad)
WS1095 (Base/Mobile) (Same as the WS1098, except lacking the numeric keypad)
The scanners below have a paid upgrade available through
Whistler, to make them DMR capable, as well as P25 Phase I & Phase II (all except the Pro-18 were already Phase II capable). This upgrade also makes them eligible for support from Whistler. All are discontinued units. Also see this RadioReference
thread.
GRE PSR-800 (Handheld)
RadioShack PRO-18 (Handheld)
Radio Shack Pro-668 (Handheld)
Your least expensive option would likely be one of the scanners in that last group (PSR-800, Pro-18, or Pro-668). Of that group, the Pro-668 would be the 'newest' of the three. Check the classifieds here on RadioReference, online sites such as eBay and Craig's List for a good condition, used unit. Don't overlook checking yard and estate sales, as well as your local pawn shops, for a lower cost unit. Skim through this
thread for what some members have found in unexpected places.
