Is there an app or any way to use my cell phone as an EMS portable?
I downloaded Zello, as I thought it acted as just that, but I am having trouble setting it up. I haven't tried to transmit with it it yet because I hear nothing coming over my local EMS frequency. I tried reading through some material abkut the app, but cant find the details I need nor do I understand the app itself.
Any advice appreciated
Zello is basically a walkie-talkie app. It can only be used between Zello users. Two or more users create a channel and then talk back and forth. It requires wifi or cellular service. Zello can not directly access radio channels. A few people are experimenting with interconnecting Zello with a radio system via the net at the hobby level, but it's highly unlikely that you could just install Zello and access a public safety system. It just ain't gonna happen.
There are a number of scanner apps available for both IOS and Android platforms. They will allow you to listen to various radio systems, but there's no guarantee that your local EMS will be among them.
Here's a simple version of how it works: Volunteers around the country use their scanners, computers, and internet connections to provide feeds. In many cases, these feeds are more than one radio channel. The feeds are transmitted to a host like Broadcastify where they are made available to scanner app users and direct listeners over the net. The app users select a feed they wish to listen in on.
There's no transmit capability in any of this for any user. It's one way listen only. And, like I said, if there's no feed for the channel you want to listen to, you're just plain out of luck. And you are dependent on the feed remaining up and running. They do go down from time to time for a variety of reasons.
If you want reliable listening 24/7 and you are within range of the system you want to hear, you're better off getting a scanner.
If you want to transmit on the EMS channel, you'll first need written permission from a responsible person at the agency and then you'll have to either be issued or purchase a compatible radio depending on how they do things there.
