pbige
Hi
School was a long time ago and my brain is mush so I have a Newbie question about a base station antenna frequency range and the local frequency range.
I would like to get an external base station antenna for my BCD996P2 the antenna that came with the unit works OK but the neighborhood I live in is kinda hit or miss with that type of antenna (at least with my old scanner)
The frequency's range from 046.000 to 465.6000 these are the numbers that I enter when programming
now for the antenna question I have seen some on Amazon like this (Tram 1410 Broad Band Discone/Scanner Base Antenna 25 to1300 MHz.-- Wide Band Receive from 25 to 1300 MHz)
would this cover the frequency range 046/465?
then there are a couple antennas that cover the
100-2000 MHz range
what should I look for that would work for me and my scanners capability
also when running the cable through the wall to the scanner I know that there is a special connector used to attach it. Is there a special tool required to put the connector on the cable end? Like the one used to put the TV fitting on with. Or do I have to drill a bigger hole? What if my cable is too long?
Thank you
100-2000 MHz range
Thank you
