Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 12-05-2017, 11:16 PM
Default LAPD Central Bureau
Hello,
I know nothing about police scanners or radios. I know someone who recently got assigned to LAPD Central Bureau, specifically Rampart Division. I was wondering if there is a scanner set up already to listen to Rampart. I browsed Broadcastify and couldn't find anything.
If there isn't a scanner set up online, I was wondering which is a good scanner to buy to listen in. Is there a special scanner that I would need to buy because I want to listen to police communications?
I do live about 23 miles from the Rampart location. Does this affect if I were to buy a handheld scanner?
The frequencies I want to listen into are here: https://www.radioreference.com/apps/db/?ctid=201 under Los Angeles City Police.
Thank you for your time.
Old 12-06-2017, 12:35 AM
need a p25 scanner. just enter the frequency, dont even need to program in a trunked system. may need an antenna on the roof of your house or car. could also get a software defined radio such as nooelec to use with the laptop and the computer programs sdr# and dsd. a software defined radio is only $20
Old 12-06-2017, 5:35 PM
So the Nooelec is the hardware that recieves the signal, sdr# is the software and dsd decodes the digital signal? Is that right or am I way off?
