Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 05-31-2018, 7:22 PM
Default Easy BCD436HP question?....
Unlike the 'old' scanners that had a scan button on them, the BCD436HP does not. What I am looking for is what button is it that will continue the scan when the radio has hit on a channel that is not of interest at the time and you just want the scanner to continue the scan.
Nothing to do with holding or avoiding a channel. You are listing to the radio it stops on a channel you want, but they are talking about nothing, so I want to hit a button ( scan, in the 'old days' ) and continue onwards - have looked at the easy to read manual - do not see anything in relation to this.
Thanks to all who respond........
Old 05-31-2018, 7:23 PM
W3JMC's Avatar
Rotating the dial at the top resumes the scan. Clock wise to scan up, counter-clockwise to scan down
John C.
RX: Uniden SDS100, BCD536HP (2), AOR AR-DV1, SDRPlay RSP2, Others not listed here
TX: BTech UV-5X3
My YouTube DXing channel:https://www.youtube.com/channel/UCE6...-sq1cDjxuT49w/
Old 05-31-2018, 9:02 PM
Smile THANKS!
I'll be a monkey's uncle - it works. Certainly, a new way to do that......
THANKS to W3JMC
Old 05-31-2018, 9:05 PM
W3JMC's Avatar
Happy to assist Welcome to RR!
John C.
TX: BTech UV-5X3
Old 05-31-2018, 10:19 PM
pinballwiz86's Avatar
Sentinel upgrade was successful! Looks just like the old one. :-D
Uniden 536HP/436HP / Uniden 396XT / Uniden 125AT / Uniden 15X / GRE 310 / GRE 120 // Ham Radio: Icom 718 / Yaesu 2900 / Yaesu 7900 / Yaesu FTM-400XDR / Yaesu FT-270 / Baofeng UV-5R+ / Icom ID-51A+
Old 05-31-2018, 11:54 PM
W8RMH's Avatar
You will enjoy your scanner a lot more if you invest a little time and read the manual.
Old 06-02-2018, 4:48 PM
I have had multiple scanners in the past - this is the FIRST one I have ever seen operates this way. Even looking at the top of the radio by the knob, it shows SELECT, VOL, SQ only, nothing about continuing scan. I did read the manual, however in the volume of information - it appears I may have missed the ONE LINE that tells you so. I even looked for some entry in the table of contents and appendix. Again, as no other scanner I have had has ever worked in this manner, why would I even assume the knob works in this manner? So I asked a question. Me bad.
Old 06-02-2018, 5:23 PM
a29zuk's Avatar
You're fine. That wasn't a question that is frequently asked. I glad someone answered your question for you. I don't mind perusing the forums and answering questions.
Something about these scanner forums....you can get some cranky responses. I find the HF forums a lot friendlier.
Jim
Tags
bcd436hb, button function, scanning
