Go Back   The RadioReference.com Forums > Scanners, Receivers and Related Equipment Forums > New User / Getting Started Forum
New User / Getting Started Forum - The place for new users to discuss how to get started, and generally feel safe from the rest of the rabid technical community. If you just got your first scanner, this forum is for you. Please note: Posts are only moved from this forum by OP's request only.
Old 06-10-2018, 2:50 AM
Default Help with Whistler TRX-1
I just bought the Whistler TRX-1. I used the EZ program software it included and put in all the systems I wanted to follow. The conventional frequencies, both analog and digital it picks up fine. However, the frequencies with a description of talkgroup wont sound. They are on my scanner, and show to be getting some signal, but no sound comes from them. Is there a way or special setting to fix this? All help is appreciated!
Just to add, I am in Texas and the departments I am trying to get are using the Texas Wide Area Radio Network (TxWARN) Project 25 Phase II
Old 06-10-2018, 6:39 AM
buddrousa's Avatar
Welcome to the forum.
Did you put these in by hand or did you import from the database?
https://www.youtube.com/watch?v=utY9BId00gU
Easier to Read Whistler WS1080/1088 Handheld Scanner and Software Manual
#1.In programming the trunking ALL FREQUNCIES HAVE TO BE ENTERED.
#2. You have to enter talkgroups also for the scanner to track.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 06-10-2018, 7:15 AM
Default No sound on trunked frequencies.
The op said he used EZ Scan. If he will send me his database, I will take a look and see what might be wrong. PM me for more info.
Old 06-10-2018, 7:39 AM
buddrousa's Avatar
I use EZSCAN and do most all my stuff by hand as I like to do it that way.
In case you did not know you can use ezscan and do things by hand and not import from the database.
I have used a version of EZSCAN from the 1st day the RS PRO18 was released.
Old 06-10-2018, 12:53 PM
Set the option in EZScam to sound noise or tone when it monitors encoded talk groups. (Advance Features/Audio options)
It might be that the TGs you are monitoring are encrypted.
/Ubbe
Old 06-10-2018, 2:25 PM
hiegtx's Avatar
Mentor
What is your location- City (or county)? Since you mention TxWARN, you obviously are in Texas. You should note the city or county, as well as sate, in your profile.
If you're in the Houston area, much of the P25 Phase II traffic, either Houston itself, or some of the other cities that are also using Phase II, is encrypted. Specifying which departments you are trying to scan will help isolate the issue. Encryption, of course, is a deal breaker. No work around. But if it's something else, the more details the better to help resolve it.
Steve
SDS100-436HP (2)-536HP-TRX-1-325P2-among others
Old 06-10-2018, 3:10 PM
Default P25 programming
If the system is Project 25, you only have to enter control channels. My fun with scanners goes back to the Radio Shack Pro 4, sold in the mid 1970's. My first digital was a Regency HX1000 in the mid 80's.
